DVD to BLU RAY Swap
whitetop137
I currently have a Samsung HT TZ215 cine system with a Sub-Woofer, Centre Speaker and 4 Satellite Speakers.
I'm looking to replace the DVD player with a Blu Ray player that I can use the speakers with...basically swap the DVD player for a Blu Ray one....
or if I buy a standalone player, how do I connect it to the current system......
Not bothered about the make........but say up to £150.....
Thanks :lease:
StevieBuck
The amplifier for the speakers is built-in to the DVD player. You would therefore need a Blu-ray player with a built-in amplifier to continue using your old speakers.
The problem however is that the only Blu-ray players that will have a built-in amplifer will be the ones that come as part of a Blu-ray home cinema package. So to get your hands on one, you'd be looking at buying a completely new system or at perhaps trying to find someone selling the main unit only from a used system.
Your best option I think is to buy a standard Blu-ray player with a digital optical audio output and use that to connect to the HT-TZ215.
Presumably you aren't already using the optical input on the cinema system?
