DVD to AV receiver
Discussion in 'Cables & Switches' started by drdavewatford, Nov 3, 2004.
  1. drdavewatford
    drdavewatford
    Sep 23, 2004
    42
    I need to connect a Denon 2910 DVD player to a Denon AVR 2805 amp for some nice movie noises.
    I guess coaxial's the best way to go, but I'm finding it hard to locate any reviews or recommendations for decent quality coax cables.....anyone got any recommendations ? 1m would be more than enough.
    While we're on the subject, I also plan to use a coaxial cable to connect the 2910 to a subwoofer (will probably get the KEF 2005.2 speakers this weekend). I'll need a longer run of cable for that, perhaps 5m. Again, can anyone suggest a quality product to go for ?
    Many thanks,
    Dr. D.
