DVD to AV Amp ?
Discussion in 'AV Receivers & Amplifiers' started by access, Aug 16, 2005.
  1. access
    access
    I have a Teac AG-7D 6.1 AV amp and I want to connect a Yamakawa DVR-625 DVD recorder to it, What is the best way to connect the audio?
    My DVD output options are
    a) 5.1 RCA
    b) Digital Coaxial
    c) Digital Optical
    What is the best connection to use?
    access
  2. hedrick@rutgers
    hedrick@rutgers
    May 9, 2005
    57
    The decision between 5.1 and digital should be made by whether you think the DACs are likely to be better in your receiver or DVD. I don't know each product so I can't guess. If you think the DVD has better DACs, use 5.1. If you think the receiver does, use digital. If you can't tell, try both. I would tend to default to digital with low-end equipment, but I'm not sure I can say why
    These days there shouldn't be any difference between coax and optical, particularly for short distances (a few feet). In the early days, optical cables tended to have low bandwidth, and could cause problems.
  3. Astaroth
    Astaroth
    Suspended
    Jun 22, 2004
    3,653
    2
    London
    +882
    As Hedrick says - it depends on which has the better decoders built in on whether you use the RCA or one of the digital connections. As a rule of thumb, unless the DVD player is several levels above your AVR or your AVR is ancient and your DVD new then the AVR decoders would tend to be better.
    There is little difference in coax or optical - traditionally coax was considered best for short runs (under 2 meters) and optical better for long runs but generally it is just a matter of convenience these days
  4. access
    access
    Thanks guys,
    the amp has the best sound processor so that makes it digital.
    access
