DVD to Amp Question?
Discussion in 'AV Receivers & Amplifiers' started by nickyvicar, May 17, 2003.
  1. nickyvicar
    nickyvicar
    Sep 13, 2002
    277
    +9
    I am in the process of hooking up my AV sytem.
    What would be the best connection for dvd to amp? I have a Yamaha 520 dvd player with coax and optical outs, a Yamaha 620 amp with coax in that the manual says is for a laserdisc player?
    Also, if i do go down the digital road, what interconnect would you recommend in my budget range £10-£20?
    Many thanks for any help.
  2. Hawklord
    Hawklord
    Feb 15, 2003
    3,424
    Aldershot, Hampshire
    +257
    I use a digital optical cable to connect to my amp from my dvdp. This one to be precise:-
    http://www.empiredirect.co.uk/productdetailsnew.asp?modelcode=QED-QNECTOT-1M
    I had the ax620 in the past and found it an admirable performer with either interconnect. I used both - one for movies (optical) and one for cd playback (coax) and used two souces so I could configure each seperately. I had movies on surround sound (whichever format available) but only listened to music in stereo.
    I'm sure you'd be happy with either and the fact that the souce is labeled as a laserdisc doesn't matter - you can use any optical source.
