DVD Storage - Please help
Discussion in 'Movie Forum' started by MJeeves, Jul 27, 2001.
  1. MJeeves
    MJeeves
    Feb 15, 2001
    4,055
    Crayford
    +224
    I know that this has been brought-up before but I can't find the older threads. I
    want to protect my large DVD collection.
    I currently store my DVD's (keep cases AND snapper cases) upright on an open
    shelving rack. My room does get quite warm in the summer, but probably no
    warmer than the inside of a DVD player. The room is clean and as dry as the air is
    (I do NOT have air conditioning or a dehumidifier).
    Is this storage solution O.K. or could it be improved? For instance would closed in
    cabinets be better than my open racks?
    I have had DVD's for over 3 years and have not noticed any deteoriate (touch
    wood!). Suggestions however, would be appreciated.
  2. PoochJD
    PoochJD
    Aug 28, 2000
    11,001
    Norwich
    +1,861
    From what you have told me so far, there appears to be no problems with you storing your DVD's in this way. This is how I store my DVD's, but luckily for me, the room stays quite cool.
    As long as the sunlight isn't directly on the area where the DVD's are, AND as long as the room doesn't get too hot, you should be okay.
    Pooch
  3. MJeeves
    MJeeves
    Feb 15, 2001
    4,055
    Crayford
    +224
    Can anyone else offer advice?
  4. Len
    Len
    err... You live in Kent don't you. I know it's warm at the moment... but the weather over here really isn't a factor. We don't have extremes of temprature. But check out www.soundstyle.net The XS180 holds 130dvds [so why not xs130?] is very stylish, and I hope to get at least two for my birthday. @cause ultimately it's a pose isn't it? :)
  5. Koosnaff
    Koosnaff
    Jun 1, 2001
    79
    9
    Kent, UK
    Just been to the site, and it says the XS180 holds 180 DVD'S !!
  6. MJeeves
    MJeeves
    Feb 15, 2001
    4,055
    Crayford
    +224
    Thank you for your responses. I'll definately check out the Sound Style site (sounds really good! 180 DVD's!!).
    I measured the temperature in my room where I stack my DVD's / CD's and it was 32 (over 90 degrees!) Is this too hot for DVD's?
  7. Len
    Len
    For some reason in the brochure I have in front of me it says 130 dvds? So hopefully it is 180... makes it even more desireable. ;)
  8. Jase
    Jase
    Mar 16, 2001
    10,815
    United Kingdom
    +2,693
    Martin
    Over here in Spain the place i´m in can go up to 40+ degrees & doesnt seem to have any effect on my dvds.
    Now the player & amp, thats a different matter!
    My amp gets bloody hot, saves switching the heater on in winter though!! :eek:
    cheers
  9. Desmo
    Desmo
    Jan 4, 2001
    14,451
    Braintree, Essex.
    +6,491
    Storage of DVD's? I find a fine layer of dust whilst being layed out in a random order around the floor works fine for me.
    I kid you not.
