dvd sound
Discussion in 'PC Gaming & Rigs' started by dubledene, Apr 15, 2005.
  1. dubledene
    dubledene
    hi chaps ive got a dvd r (liteon) and i cant seem to get any sound on it?? i play games abd the sound is there any ideas tia
  2. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,740
    2
    In a secret location with Jennifer Lawrence
    +9,526
    A bit more on what other components are in your system would be a start. How is it connected? What do you mean you play games and there is sound??
  3. dubledene
    dubledene
    its connected by an ide cable !! if that helps music can be played through the pc but no sound on dvds
  4. Greg Hook
    Greg Hook
    Nov 25, 2001
    22,740
    2
    +9,526
    so the music works in the dvd drive and games work properly but no sounds comes from DVDs? What DVD software are you using?
  5. dubledene
    dubledene
    windows media player
