DVD Soon's website
Discussion in 'Blu-ray & DVD discs' started by michaelm, Nov 3, 2003.
  1. michaelm
    michaelm
    Aug 13, 2001
    678
    Belfast
    Has anyone been able to log on to or order from DVD Soon's site. I haven't been able to order for a few days now, it will not accept my password and the logon screen seems to be stuck in a lop.
  2. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +235
    Getting logged in here okay m8.
  3. damtom1
    damtom1
    Yep...me too.........just ordered fine.
  4. BIONIC MAN
    BIONIC MAN
    Jun 26, 2002
    956
    Nasa
    +40
    I also can not log on from work :mad:
    This is since I have lost my Pc at work and been giving a
    Winterm ! ! , and I would say the guys in out It department
    have put a block on the net going into a Secure site ? ? :suicide:
    Well thats what I think , as I can use the site at home no Prob's
    :smashin:
  5. dolph
    dolph
    Dec 16, 2002
    1,191
    48
    +26
    Check your security settings for internet explorer (if you can get to them)
  6. BIONIC MAN
    BIONIC MAN
    Jun 26, 2002
    956
    Nasa
    +40
    Hi thanks for the reply
    I can get into my settings , but what do I need change
    Thanks for the help
    :smashin:
  7. stretcher
    stretcher
    Jun 25, 2002
    496
    Between Ashford (Kent) & Canterbury
    +8
    Well I can't even create an account, let alone login.
    Security setting in IE were dropped to low and still didn't make any difference. Haven't had this sort of problem before:confused:
  8. michaelm
    michaelm
    Aug 13, 2001
    678
    Belfast
    Turned out I was using the wrong password, checked my emails and there it was. The site definitely doesn't work properly though. I couldn't request my password and until I entered the correct one I was just stuck in a loop.
