DVD sleeves
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by jsadts, Feb 28, 2005.
  1. jsadts
    jsadts
    Jan 9, 2003
    9
    Copenhagen, Denmark
    Hi there,
    Not sure this is the right forum part to ask this is in, but here we go:
    I've been looking into a solution for storing all my movies in less space (also has high WAF score!:). For that I want some sort of sleeves in plastic or similar, which is able to hold 1-2 DVDs in each sleeve including the film cover (hence not the standard CD-sized sleeves that can be found in abundance).
    I have googled around, and the only solution I can find is the one at www.mmdesign.com called DiscSox DVD Single/Double or DVD Pro. They look to be exactly what I want but they are a bit expensive, and they do not seem to have an European distributor (hence high shipping costs from US).
    Anyone know of any (less expensive) alternertives to DiscSox available in Europe?
    Thanks!
    - jsadts
  2. krungthep56
    krungthep56
    Oct 1, 2004
    178
    Cheshire
    +6
    Have been looking meself for something that would diminish the 500 or so DVD's I have littering (the wife's expression) the lounge. Good try on the sleeves, any other suggestions would be welcome.
    Give us a shout if you find anything.
    Regds,
    HT
