DVD SACD with regulated line-out??
Discussion in 'Blu-ray & DVD Players & Recorders' started by beemer, Sep 28, 2003.
  1. beemer
    beemer
    I have a question, im building active speakers. Do i need to build a pre-amp too, or are there players on the market with 5.1 analog outputs, who can be regulated (volume) due remote, so that i can connect the player direct to the active speakers??. This way i can "skip" the pre-amp.
    Who can give me an answer, i'm intyerested in the pioneer DV 747-a, can it do the job??. thx, andre
  2. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    Mostly budget player (not all though) have this functions only. AFAIK.
    Don't think the Pioneer does but I could be wrong ...
  3. beemer
    beemer
    Can you please give me some player names?, and types, that you are sure off. Mabey a pioneer user can reply, thanks...
  4. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    Sorry, no idea. As you can see I live in Taiwan and the models sold here differ from the European ones ...
  5. andymc
    andymc
    Sep 18, 2003
    261
    Bedford
    +15
    Beemer,
    I have recently been doing my homework on SACD and DVD-A and have bought one of each and this is what I am lead to believe from my experience.
    All players have audio outputs and when used in SACD mode only the AUDIO outputs work - there is no digital output for SACD as the whole disc uses a different system (Direct Stream Digital) to that of normal CD/DVD PCM. My Pioneer 565A player has 6 phono outputs which I have connected to the amp imputs to give me the sound.
    DVD-A still uses 96khz and therefore MIGHT send a digital signal but also uses the audio outputs. In most cases you have to tell the player what to out put and to where.
    Hope this helps
    Andy C
