dvd-rw recording question
Discussion in 'Blu-ray & DVD Players & Recorders' started by stringman, Sep 23, 2004.
  1. stringman
    stringman
    Hi all,
    This may be a stupid question but:
    If I record a film on to the dvd using the timer I usually let it run on for 10 or so minutes. Can I then start the next recording at the end of the film ( ie like rewinding a vhs a bit) or is it not as simplie as that? I am using a pioneer 320 and recording in video mode not VR mode.
    Thanks in advance
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,721
    Warwick
    +2,599
    It's not as simple as that if you use DVD Video mode! Programmes you record can't be editted in anyway (including starting a new recording at a given point). You'll need to use VR mode for that kind of functionality (which will allow you to chop the start and end - as well as anything in the middle - out).
  3. stringman
    stringman
    Thanks for that.
    If I use VR mode Then i presume that the disc will not play on my other players inc my portable. Is that correct
  4. ernet
    ernet
    You're right . Only very few DVD players/recorders accept VR. However I can't name them.
