DVD+RW playing problem with Venturer PS166W
Discussion in 'Video Streaming Boxes & Services' started by dholliss, Sep 21, 2004.
  1. dholliss
    dholliss
    First post here, think I've got the right forum, I have a Portable Venturer PS166W
    (linky http://www.argos.co.uk/webapp/wcs/s...001&langId=-1&catalogId=2501&productId=111763 )
    It plays all kinds of discs (I have a region free code) but it won't play DVD+RW's I have burnt on a Goodmans DVDR-300 DVD Recorder, I know it doesn't say it does in the blurb but I can't believe it wont. Prehaps it's a finishing problem or similar ?
    Any help appreciated.
  2. w3dal
    w3dal
    Aug 4, 2002
    5,053
    Chelmsford, Essex
    +588
    Have you tried burning a DVD -RW.
    For me the more supported format is -r and -rw
    I would say its a compatibility issue with either your discs or simply the drive wont play them.
    Get some -rws
    Dal
  3. brummybloke
    brummybloke
    Jul 18, 2004
    91
    depends what media you are using also, some lasers are more fussy than others. was going to say about the burn speed but on a stand alone i guess it doesnt record at x8?
    and yes dvd-r do seem the most popular although again stand alones mainly just use + media.
    try a more expensive dvd+r
