DVD-RW on the Tosh 220e
Discussion in 'Blu-ray & DVD Players & Recorders' started by poggs, Jul 5, 2002.
  1. poggs
    poggs
    Has anybody got any makes of DVD-rw to work on the 220E? I have managed to get all makes of dvd-r I have tried working just fine but no DVD-rw's
    Anybody had any better luck?
  2. Peter Shilton
    Peter Shilton
    Jun 8, 2002
    213
    19
    Solihull
    I have used a LITE ON high speed 4x-10x 650MB CD-RW and not had any problems.
    I'm not saying others don't work, but just that the only one I had i have used and it read it without any problems.
    I have firmware 1.4, if that makes a difference. Check which firmware you have.
    There is a thread on here about it and how to check it.
    Hope this helps.
  3. poggs
    poggs
    All cdrw's are fine its DVD-rw im having problems with
    thanks
