DVD RW Drive for PC
Discussion in 'Desktop & Laptop Computers Forum' started by sapper, Aug 9, 2003.
  1. sapper
    sapper
    Jul 20, 2000
    2,232
    Southgate, North London
    +141
    HI all,
    what is the currrent preferred DVD drive for a home PC.
    Priamtrily to be used as a stroage device.
    The Panasonic was looking good ~2 months ago.
    Any commnets?
    Sapper
  2. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,231
    UK.
    +2,767
    The Pioneer 106 looks reasonable and it does both -R and +R. It also burns at 4 times for the media that allows it.
    Was around £129 from Bigpockets and Blankdiskshop.
    HTH
    Gary.
  3. CooperUK
    CooperUK
    Jun 30, 2003
    2,213
    Hampshire
    +304
    Try looking at this site
    particularly here
  4. CodeThief
    CodeThief
    May 25, 2002
    663
    UK
    +5
    DAMN!!! Thats cheap :smashin:. Is there something else on the horizon thats dropped the prices?
    Dave
  5. gab2001uk
    gab2001uk
    Dec 3, 2002
    236
    +5
    Good prices there.
    I use the Sony DW10A. I use +RW for testing purposes, then use 4X -R for archiving, as -R are cheaper than +R, especially the printable ones.
