DVD+RW compatibility
Robstar
I'm trying to find out if the Toshiba SD-510 is DVD+R / +RW compatible. I can't seem to find information on it anywhere. www.dvdplusrw.org doesn't list it at all.
Does anyone know of a good source for this info?
TIA
michaelab
www.dvdplusrw.org is probably the best place for that kind of info. I don't think you'll get it officially anywhere. The list on dvdplusrw.org has been compiled by user reports so it's not exhaustive but of the 40 or so Tosh players listed only one (the SD P 1500) is listed as not supporting either +R or +RW so I would suggest it's highly likely that the SD-510 is compatible.
You could always ask on the 'compatability' forum on the site to see if anyone knows.
Michael.
Podcast: Best Home Cinema Sources and B&W 805 D4 Speaker Review and more...
