Dvd-rw and RGB in.
Discussion in 'Blu-ray & DVD Players & Recorders' started by Kasparaitis, Sep 23, 2004.
  1. Kasparaitis
    Kasparaitis
    Can someone please tell me the cheapest dvd recorder which has both RGB in and burns to dvd-rw.
    They all seem to have one or the other.
    Thanks.
    Ed
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    Take a look at the Pioneer 220.
  3. Kasparaitis
    Kasparaitis
    That looks like a good one.
    Is it available in any shops because I'm a bit worried about buying from the internet and the thing going tits up. I presume if I buy from the internet and it goes wrong then i have to be for it to be sent back to the depot whereas If i get it from a shop then I can just take it back to them.
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
  5. Kasparaitis
    Kasparaitis
    Thanks, think I might order one then.
    You have been VERY helpful and a credit to this forum
  6. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    Shhh! You'll upset my critics :hiya: :)
    Glad to have help.
  7. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    Don't forget the Toshiba model(or the latest one anyway)
  8. Kasparaitis
    Kasparaitis
    @ phelings
    do you mean the one thats the RDXS32 thats about £380?
  9. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    Yes - he was referring to the RDXS32 - an excellent HDD/DVDR and one I recommend without question (but I didn't in your case as you asked for the cheapest available). A non-HDD Toshiba DR3 will be available in a couple of months which will offer RGB input and DVD-RW recording if you are happy to wait - but will probably be about £50 more than the Pioneer (but offer several more features: Prog Scan, component, DVD-RAM etc).
  10. waz2004
    waz2004
    Sep 14, 2004
    296
    +6
    what about panasonic 55?
  11. Kasparaitis
    Kasparaitis
    doesn't do dvd-rw
