DVD-R's on normal DVD players?
Discussion in 'Blu-ray & DVD Players & Recorders' started by bignairy, Jun 6, 2004.
  1. bignairy
    bignairy
    Mar 13, 2004
    96
    OK, this is a dumb question to some of you, but if I use a DVD recorder, can the discs I record be played back on a normal DVD player?
    So if I say, record a movie from Sky, will my daughter be able to play the disc on her bog standard Ronin DVD player? :)
  2. Kevo
    Kevo
    Aug 23, 2001
    5,408
    Manchester
    +151
    More than likely.
    So far I have played DVD-Rs on a 5 year old Pioneer, Toshiba, 100E, 110E, xbox and a Sony DAVS 300 with no problems at all.
  3. bignairy
    bignairy
    Mar 13, 2004
    96
    Thanks Kevo - you are a gentleman and a scholar.
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,397
    Rainham Essex
    +2,452
    To make sure the player will play recorded DVD's then have a look Here and search for your model. It will list what it is likely to be able to play although there are no guarentees as a lot of other things can stop a disk from playing.
    Mark.
