dvd rom drive help
Discussion in 'Blu-ray & DVD Players & Recorders' started by MrFurious, Jun 18, 2003.
  1. MrFurious
    MrFurious
    Sep 9, 2000
    14,304
    Cardigan Wales
    +1,545
    i have just had a dvd rom drive installed,i have a few questions,is there anyway i can make the drive play r1 and r2 dvds,it came up on screen when i inserted a r2 that there are 5 times before it gets set.also when i play a dvd the picture is fine but the sound is a bit bitty and distorted a touch???any help appriciated.
  2. nathan_silly
    nathan_silly
    Stevegreen asked similar question (firmware flash) do a search, I and SG helped him out.
    Not sure why sounds is distorted... have got got latest s/c drivers?
    If you run out of changes it'll lock to the current region.
    After flashing, use DVD genie to change the Windows region. Also since you've flashed it, it'll allow unlimited changes.
  3. MrFurious
    MrFurious
    Sep 9, 2000
    14,304
    Cardigan Wales
    +1,545
    thanks i just d/ld the genie,now i have to sort the sound out its driving me mad
  4. nathan_silly
    nathan_silly
    You need to flash the drive. Otherwise it'll lock the drive and you won't be able to change it (say it'll be stuck on R1, and impossible to change to R2).
    check here..
    www.firmware-flash.com
  5. MrFurious
    MrFurious
    Sep 9, 2000
    14,304
    Cardigan Wales
    +1,545
    not sure what make it is,i think it was arcan or someting like that
  6. nathan_silly
    nathan_silly
    Link to all drives...
    http://forum.rpc1.org/dl_all.php
    and a util to check what make/model your DVD drive is, what region and how many changes left.
    I would triple check that the reported drive is actually the one you have (remove the DVD-ROM and look for make & model no)
  7. nathan_silly
    nathan_silly
  8. MrFurious
    MrFurious
    Sep 9, 2000
    14,304
    Cardigan Wales
    +1,545
    Thanks for your help mate,i am a bit unsure about changing things,but my mate owns his own pc building company and he upgrades my pc all the time so he can do it for me!!!I think the sound issue could be that the card a soundblaster 16 is the only piece of kit remaining from the original pc i bought in 1995!!!!!time to buy a new card i think.:D
