DVD ripping to PSP
Discussion in 'Playstation Forums' started by Carlosis, Sep 12, 2007.
  1. Carlosis
    Carlosis
    Jun 4, 2007
    619
    Windsor
    +8
    Ok so i'm getting the new psp on friday and wanna put loads of films and tv serie s onto it.
    Who can reccommend me a good program to do it? i wanna put on certain episodes of some dvds etc.
    Any help would be swell.
  2. markbigears
    markbigears
    Dec 30, 2003
    516
    chalk, Kent
    +18
    dvd shrink or dvd decrypter and PSP video 9. Easy to use and great quality. I use them all the time. Have fun
  3. ukbootlegs
    ukbootlegs
    Feb 7, 2006
    4,077
    Northants
    +367
    I found the best thing for converting avi is
    3GP_Converter033
    I am sure you can get tools to rip from dvd to ipod too
    I just never need to do it
    here is a list of tools for the job of dvd conversion to ipod tho
  4. RMGEE
    RMGEE
    Apr 28, 2006
    2,600
    Worcestershire
    +655
    Just received my new PSP Slim & Lite, can anyone tell me the best / safest place to download DVD Decryptor and PSP Video 9.
    I'm new to all this and don't want to get any viruses or spyware on my PC.
    Rich.
  5. markbigears
    markbigears
    Dec 30, 2003
    516
    chalk, Kent
    +18
  6. RMGEE
    RMGEE
    Apr 28, 2006
    2,600
    Worcestershire
    +655
  7. markbigears
    markbigears
    Dec 30, 2003
    516
    chalk, Kent
    +18
    Hope you bought at least a 2GB one if you want to save films on it
  8. RMGEE
    RMGEE
    Apr 28, 2006
    2,600
    Worcestershire
    +655
  9. markbigears
    markbigears
    Dec 30, 2003
    516
    chalk, Kent
    +18
    nice one, plenty of space on that. Quality is fantastic on the screen.
  10. scaffolderus
    scaffolderus
    Aug 17, 2005
    129
    +12
    A neat but more expensive alternative is to buy a Neuros MP4 recorder which will record from a DVD player, Video, TV, Sky or Freeview box straight onto a Memorystick without using a PC. The files appear to be a bit smaller than the default PSP9 settings but the quality is still excellent. The advantage is that it's really just a video recorder so there's no converting to do - you just record in real time.
    The only disadvantage I've found is that everytime you upgrade the PSP firmware, the PSP won't play the old MP4 files (I store them on my PC) and you have to upgrade the Neuros box. Easy to do, but a bit odd because the PSP9 files I have play with no problems on all firmware versions. I've still got mine set up for PSP v2.5 so I'll need to update the Neuros software before I start using the new PSP.
    Hope this helps
  11. Scotty
    Scotty
    Feb 12, 2002
    1,468
    Home Counties
    +410
  12. Reepicheep
    Reepicheep
    Aug 5, 2002
    583
    28
    Leicestershire
    +51
    I use AnyDVD and CloneDVD Mobile :)
    Quick and easy.
  13. RMGEE
    RMGEE
    Apr 28, 2006
    2,600
    Worcestershire
    +655
    I'm thinking of buying ImTOO DVD Ripper Platinum v4.0 as it looks like an easy way to rip DVD to MP4
    Has anyone had any experience with it ?
    TIA
    Rich
  14. Kube
    Kube
    Mar 21, 2005
    5,384
    Armagh
    +369
    Why would you pay for anything when DVD Decrypter and PSP video9 do it for free?
  15. RMGEE
    RMGEE
    Apr 28, 2006
    2,600
    Worcestershire
    +655
    I know what your saying its just that I'm lazy :)
    I tried using DVD Shrink (already downloaded a while ago) with PSP Video 9 last night, but when trying to convert using PSP Video 9 it got to 100% but kept on converting and wouldn't stop.
    I'll try downloading DVD Decrypter tonight.
    Rich.
  16. Kube
    Kube
    Mar 21, 2005
    5,384
    Armagh
    +369
    PSP Video 9 does that. It can go to 100% very quickly but may infact only be 5% through the process. I dont know why it does it. The best way to calculate with PSP video 9 is to knwo roughly the lenghth of the film, say. 120 mins. Multiple by 60 and it gives you the total number of seconds. When you are converting using PSP Video 9 use the seconds counter (under conversion statistics) on the left hand side as a measure against the total seconds of the film.
    Or simply look at the file size when your converting it. A 2hr film will come in at roughly 550-700mb.
  17. nick501
    nick501
    May 6, 2005
    7,217
    Walsall, West Midlands
    +782
    does psp video 9 remove the copy protection.
    I put some cheap cartoons on my sons psp with sony's 'media manger for psp' no problem but trying other ones for him like, say pingu on dvd, would not copy (they didn't even show in the transfer list). I'm assuming it due to the copy protection.
    surely it's legal if i own the original?
  18. RMGEE
    RMGEE
    Apr 28, 2006
    2,600
    Worcestershire
    +655
    No, it doesn't remove copy protection, as far as I'm aware it only converts files to MP4.
    To remove the copy protection you need to use a programme like DVD Shrink or DVD Decrypter etc...
    Rich.
  19. Kube
    Kube
    Mar 21, 2005
    5,384
    Armagh
    +369
    DVD Decrypter is superb. Very fast app.
  20. nick501
    nick501
    May 6, 2005
    7,217
    +782
    so psp video 9 is useless if a disc is copy protected? I mean i may aswell stick with media manager for psp?
    as you can see i have no clue about this sort of thing!
  21. RMGEE
    RMGEE
    Apr 28, 2006
    2,600
    Worcestershire
    +655
    I'm new to it all as well, I only got my PSP on Monday so were both in the same boat. :)
    Rich.
  22. Kube
    Kube
    Mar 21, 2005
    5,384
    Armagh
    +369
    PSP video 9 is only used to converter the DVD VOB files to MP4. You need DVD Decrypter to get the VOB files off your DVDs in the first place - hence the copy protection doesnt matter.
  23. nick501
    nick501
    May 6, 2005
    7,217
    +782
    Ok i've got it now.
    Dvd decryptor first on pc then media manager(or whatever) to transfer to psp.:thumbsup:
    1gb memory stick isn't enough is it? lol.
  24. Reepicheep
    Reepicheep
    Aug 5, 2002
    583
    28
    Leicestershire
    +51
    I have AnyDVD that strips the copyright protection off. Then I use CloneDVD Mobile to convert to PSP format or MP4 (and other mobile formats like moble phones etc.) It allows you to strip out all the rubbish like adverts, subtitles and unwanted audio files. You can then select the quality (and size) of the converted file and select a still from the film for the thumbnail image :)
    Both AnyDVD and CloneDVD Mobile are available as free demos valid for 30 days.
  25. scaffolderus
    scaffolderus
    Aug 17, 2005
    129
    +12
    I said earlier that I'd had some problems with the Neuros MPEG4 recorder and PSP firmware compatibility. I was proabbly a bit unkind because there is a fix on the Neuros site that sorts it. I've updated my recorder and it works fine now with the new PSP. My gripe was that I'd got about 20 hours' worth of Neuros recodings on my H/D which wouldn't play on my PSP with versions 2.7 or later. Fortunately, I've discovered if you take the MP4 files out of the MP Root folder and drop them in the ordinary "Video" folder, they play no problem. You loose the thumbnail but you can rename the file for ease of reference.
    I use the free downloads and PSP9 is brilliant, but I wouldn't be without the Neuros. You can record straight on to a memorystick from almost any source and you don't need to use a PC. I admit it takes all the fun out of ripping DVDs - extracting and converting files, tying up your PC while you're doing it, crashing the H/D and having to reboot, etc, etc!
    I've also bought a PMR bluetooth 3.5mm dongle from (£20 from Maplins) which works a treat with my Motorola S9 and HT820 phones.
    Cheers!
  26. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    If you have an MP4 in the 'Video' folder just drop in a 160x120 .jpg file into the same 'Video' folder with the same name as the .MP4 file and you'll have a still thumbnail image for your video. :thumbsup: e.g. if you have a video called 123xyz.mp4 just grab an image from the net, or make your own and call it 123xyz.jpg. I'm not sure if the image has to be 160x120 but I stick to that resolution and the thumbnails always seem to work.
    S.
  27. adonis
    adonis
    Sep 6, 2005
    2,272
    +178
    is there anything for Mac OSX for conversion?
  28. madada
    madada
    Mar 26, 2007
    50
    Hornchurch, Essex
    If you are using custom firmware on your psp and you sync it using sony media manager it will mess up game folder so you wont be able to run your iso's.
    This is just a warning as i found out the hard way friday when i was converting some divx films using PSP video 9 .
  29. sparkz
    sparkz
    Nov 21, 2002
    219
    19
    Southampton
    Anyone had any luck converting any DVDs to PSP H.264 format (480x272)?
    I've tried just about every tool I can find and they all give the same result: the dreaded "unsupported data". Latest tools tried include PSP video 9, Jesterware, Xilisoft, TMpg and a few others who's names I've forgotten as they didn't stay very long!
    The files are loaded onto the MP_ROOT\100MNV01 folder with M4V10001.MP4 and M4V10001.THM names as is the correct way afaik. This is on a SanDisk 4GB duo.
    The MP4 files play ok on the PC.
    Is this possible that it isn't possible on my firmware (3.7)? They didn't work on the earlier version I had either (3.3). :suicide: Is it a case of needing an even earlier firmware? Locating the files in a different folder?
  30. RMGEE
    RMGEE
    Apr 28, 2006
    2,600
    Worcestershire
    +655
    I am very new to this but I think that if you are running current firmware then all videos now go into the "video" file not the MP_ROOT file, thats where all my videos go into after converting to MP4.
    What is the difference between MP4 and H.264 ?
    Rich.
