DVD Ripping for MCE My Movies
Discussion in 'Microsoft Windows' started by PannyAdams, Feb 11, 2005.
  1. PannyAdams
    PannyAdams
    Dec 5, 2004
    661
    Epsom
    +5
    I am about to rip my collection of DVDs on to my HTPC hard drive to play back via My Movies. What is the best ripping software? And what format does it produce? I beleive MyMovies only plays the extentions mpg, mpeg, avi or mp4. I value quality over compression.
    Help!
  2. lisag
    lisag
    Jul 14, 2004
    5,985
    Essex
    +397
    Auto Gordian Knot - use Xvid compression, quality is awesome :thumbsup:
  3. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,469
    Southampton
    +188
    My Movies will do DVD ie VOBs
  4. Danieluwe
    Danieluwe
    Dec 17, 2004
    311
    +88
    If quality is the highest priority i reccomend DVD Decrypter,
    This will pull the entire contents of a dvd from a disc and put it on your hard drive, while stripping out stuff like macrovision,
    This will create files that are compatible with mce2005 and my movies,
    Then if you want you can use a program such as clone dvd which can get rid of stuff like extras and the menus if you want, this program also gives you the option of reducing the bitrate to get a smaller file size,
    Personally i rip with dvd decrypter and then use clone dvd to strip out all the menus and extras leaving just the film at full quality,
    If you take this route you will need a lot of hard drive space but is definatly worth it if this is not an issue.
  5. newstuart
    newstuart
    Apr 22, 2004
    1,680
    Northumberland
    +60
    has anyone got any ideas on getting this to work on 2004 edition (my DVDs) as it will not play video ts files ?
  6. PannyAdams
    PannyAdams
    Dec 5, 2004
    661
    Epsom
    +5
    Ok. Done a test rip with DVD Decrypter. When I play back from My Movies I get an "Unknown Error" from Window Media Player. But it plays in Windows Media Player in XP?
    Next, the play back in WM10 in XP isn't great the blacks are washed out and the detail isn't great. When I playback in PowerDVD it is awesome. Help me get through my MCE teething problems as my wife loves the front end!!!! Help!
  7. zAndy1
    zAndy1
    Nov 26, 2002
    19,922
    2
    5
    163
    +7,031
    I've also found the playback within MCE to be 'lacking'. Hence my purchase of Theatertek which is fantastic!
    Andy
  8. Danieluwe
    Danieluwe
    Dec 17, 2004
    311
    +88
    Ok lets try and get my movies working first, when you rip a dvd with dvd decrypter in should create a folder labelled video_ts this needs to be placed in a sub-folder, generally just name this folder the name of your film, so it would be c:\your dvd\video_ts then when you enter the film details in my movies select the folder containing the movie (i.e c:\your dvd) then when you select watch through my movies it should play as if you have just inserted the disc itself, but as it sees the files as a dvd disc you will need to have installed a dvd decoder into your system (i reccomend nvidia dvd decoder). This should work fine, also make sure you have the newest version of my movies (v1.1).
    Not sure about the picture issues try this and see what its like and then maybe you can tweak the set,
    Dan
  9. lisag
    lisag
    Jul 14, 2004
    5,985
    Essex
    +397
    Hi, think I have replied to you on a separate thread, how are you getting on? It definitely sounds like a codec problem that MCE is rejecting. Try uninstalling all codecs and re-installing just PowerDVD6 then check that you get an extra Cyberlink Program in the settings menu of MCE (from the start menu). You then need to add Xvid codec and AC3 filter if you need them for playing back Xvid encoded films and AC3 encoded audio.
    BTW - just got round to setting up My Movies - awesome! :thumbsup:
  10. zAndy1
    zAndy1
    Nov 26, 2002
    19,922
    2
    5
    163
    +7,031
    You do have daemon tools installed don't you? My Movies needs it I think so if you haven't got that installed try that first!
    Andy
  11. lisag
    lisag
    Jul 14, 2004
    5,985
    Essex
    +397
    I haven't got it installed and mine works ok?
    I only have my movies set up for playing avi files from hard drive though, daemon tools is for offline DVD's I believe?
  12. zAndy1
    zAndy1
    Nov 26, 2002
    19,922
    2
    5
    163
    +7,031
    No daemon tools is for online dvd images, My Movies uses it to mount the image as a drive letter which can then be played in MCE. I'm not sure if that also applies to DVDs ripped as VOBs in a VIDEO_TS folder but I think it does. The fact your only playing AVI files explains why you don't need daemon tools.
    Andy
  13. lisag
    lisag
    Jul 14, 2004
    5,985
    Essex
    +397
    Oh, that makes sense - thanks :smashin:
  14. Danieluwe
    Danieluwe
    Dec 17, 2004
    311
    +88
    My movies only needs daemon tools if you store your dvd images as .iso's
    If you store them just as video_ts folders then it is not needed,
    All daemon does is mount the iso's into a virtual drive on your system, but the same thing is acheived by using the video_ts system just without the need for an extra drive letter.
