DVD ripping and streaming?
Discussion in 'Playstation Forums' started by Pepi677, Feb 4, 2009.
  1. Pepi677
    Pepi677
    Oct 21, 2006
    22
    I run a windows home server and was wonding what is the best format for ripping a dvd to enable it to stream to my PS3.
    Also I have bought a copy of Mad about you season 1. When I load the DVD on a player there are 11 episodes, when I view it on the PC as a player there are 11 episodes.
    However when I try to recode it using either Nero 9, Handbreak or Clonedvd Mobile, it only shows 8 episodes, there are 3 others show in extras at 21 minutes each the same as the the others, but I am unable to recode them.
    An ideas?
  2. Axum
    Axum
    Aug 27, 2007
    6,139
    +805
    I would use DVDShrink and rip the various .vob files through that. Turn on sequential playback and then play via USB (making sure that no one .vob is bigger than 4GB), or stream as one large .vob. If you're using Windows Media Player 11 you'll need to rename them to .mpgs.
