dvd RGB to non component projector
Discussion in 'Projectors, Screens & Video Processors' started by amrds, Dec 7, 2003.
  1. amrds
    amrds
    I have a pioneer 717 dvd player which has Scart RGB, s-video and composite ouputs. The projector is an ASK C100 (native XGA) which has DVI, VGA, s-video and composite inputs. It is currently setup using s-video. Tried connecting the dvd player via a scart to RGBHV converter (CSR 2200) but the projector image was all over the place, believe this is to do with the resolution not being supported by the projector.
    Is there a way to get the scart RGB to VGA working? Or should I stick with s-video?
    thanks.
    :confused:
