J
jda
I've been recording the X-files on FX using the method outlined in the DVD-RAM
ie Use FR135 to give 2hr 15mins for 3 episodes.
I forgot to switch into Fr135 mode and recorded 1 episode on LP.
Now Tmp DVD author complains about the resolution.
Two eps are 720x 586 (full D1) and the odd one is 480x586
Any ideas on how to get this to work, not sure if changing the headers would work as the playback would also be changed.
How about this....
Use a header editor to change head to fool TMP author to thinking its a 720x586. (restream?)
Then use IFOedit to edit the vobs and change the resolution back to 480x586.
Would this work???
Any other ideas???
Thanks,
Jim
How about this....
Would this work???
Any other ideas???
Thanks,
Jim
