DVD Region settings
Discussion in 'Desktop & Laptop Computers Forum' started by hughesy, May 14, 2005.
  1. hughesy
    hughesy
    Jan 22, 2005
    846
    Irish in Oz
    +13
    Hi guys,
    On most Pc's there is a limited amount of times that you can change the region settings on your PC's DVD drives (about 5 times).
    i unfortunetly have run out! :mad:
    Does anyone know anyway of resetting this???
    Thanks,
    Connor :cool:
  2. Stellavision
    Stellavision
    Apr 7, 2003
    2,251
    Southsea, UK
    +84
  3. MikeFish
    MikeFish
    DVD drives can be hardware locked and software locked.
    You can get around the software lock with something like DVD Genie.
    Some drives cannot be hardware unlocked. Use 'disc info' to find out the state of your drive. If it is hardware locked you might be able to update the firmware or use some sort of crack. Sorry to be a bit vague but I'm on the way out. I can dig out more info & links later/tomorrow if you're still stuck.
