DVD region 1.. better ?
Discussion in 'Movie Forum' started by GIE, Jan 22, 2008.
  1. GIE
    GIE
    Jan 22, 2008
    4
    I live in south east asia & usually buy and watch region 3 dvd movies.
    Somebody said that region 1 DVD has better picture & sound quality than the region 2 and region 3, even the feature as well.
    Is that true ?
  2. partyweb
    partyweb
    May 7, 2002
    6,449
    It's Peanut Butter Jelly Time!!!
    +529
    Not really true (unless you are buying the pirated versions that are readily available in Asia ;)). Very often I would say the R3 dvds can sometimes be better as many have a DTS track that can be missing on the R2 & R1 versions.
    Sometimes though, the R1 version may have extra features or a commentary track that is missing on other regions.
    :hiya: Welcome to the forum BTW.
  3. GIE
    GIE
    Jan 22, 2008
    4
    Ofcourse, no pirated versions..:)
  4. sore napper
    sore napper
    Sep 2, 2006
    3,651
    Co.Antrim
    +248
    All depends on how they master the dvd.
    Region 1 and 3 are NTSC and Region 2 is Pal, in theory Region 2 should look better because of the Pal System. More lines in the picture, or something. I'm sure someone could explain it a lot better than me.
    of course you would need to make sure that you're DVD Player and TV play Pal, most do, but best to check.
  5. soundstory
    soundstory
    Feb 15, 2006
    4,414
    +229
    I'd add that though technically R2 is better, it does tend to show flaws on older movies :)
