DVD Recs 5.1, 6.1, 7.1? Confused!
Discussion in 'Blu-ray & DVD Players & Recorders' started by The_Mole, Mar 7, 2005.
  1. The_Mole
    The_Mole
    Thinking of buying Yamaha DSPAX750 A/V Amp. 6.1, 7.1 Brilliant! Cannot find any information on DVD Recorders regarding 6.1 or 7.1. Please help :lease:
  2. musukebba
    musukebba
    Jan 11, 2005
    689
    +16
    That's because none of them record 5.1, let alone 6.1 or 7.1.
  3. The_Mole
    The_Mole
    Looking to play 5.1 or 6.1 with, but not absolutely necessary, 7.1
  4. Ryu
    Ryu
    Dec 9, 2004
    251
    +23
    DVD Recorders like DVD Players usually have an optical out that pumps out the digital audio bitstream to the AV Receiver. It is whilst this stream of binary information is being processed that the amp decides if it is a 5.1,
    6.1, 7.1 etc signal depending on the flag assigned to the signal. The flag signal is encoded on the disc. So in answer to your question as long as the recorder/player has an optical out then it is down to the reciever to do the conversion to 5/6/7.1.
  5. The_Mole
    The_Mole
    Thanks 4 the advice Ryu. Looking 4 ages at reviews. Will be easier to make a choice.
