DVD recording !!
Discussion in 'Blu-ray & DVD Players & Recorders' started by ascotford, May 16, 2001.
  1. ascotford
    ascotford
    I got the following email from Maplin is this true !!!
    The macrovision should not be affecting the sound, it just messes up the sync levels of the video,so I have no idea why the sound is breaking up.
    It is a shame to use a dvd with a modulator. We actually sell a video enhancer which will remove the macrovision before it gets to your video recorder and should remove the requirement for a modulator.
    The order code is TB79 at £49.99 if you want to try it.
