DVD recording software
Discussion in 'Desktop & Laptop Computers Forum' started by lcarter, Jan 13, 2004.
  1. lcarter
    lcarter
    I am waiting to receive Pioneer 106 (OEM) DVd re-writer and would like to know what DVD recording software is best/cheapest for this recorder. All I really need (I think) is to purely copy DVD's that I record onto DVD-R from my Panasonic DMR-HS2.
    Any information would be helpful
    Txs :hiya:
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,121
    Rainham Essex
    +2,389
    If all you want is to do direct copies of other DVD's then all you need is a CD/DVD burning prog such as Nero 5.5 or 6.
    If you want to add menus &/or chapters then you will need something like Ulead DVD Moviefactory 2.
    I use both the above progs with my Pio 106 and they are very easy to use and give good results.
    Mark.
  3. lcarter
    lcarter
    Hello Mark
    this is getting to be a habit - thanks for your input - already have Nero 5.5, so will save me a bit of money there. Will wait to receive the Pioneer 106 and mess about with Nero and if need anything else will certainly try Ulead DVD Moviefactory 2
    Ta again.
  4. lcarter
    lcarter
    Mark
    I have just thought of something else regarding direct copying of my DVD's. When I record films onto the DVD-R I normally get 2 films on LP. When I copy these will I get everything I recorded onto the copy DVD-R (i.e. both films about 4hrs), or should I start recording just 1 film per DVD-R?
    If you can help will appreciate it
    Lynda:confused:
  5. gab2001uk
    gab2001uk
    Dec 3, 2002
    236
    +5
    As the Panasonic also uses recordable DVD, and you are not copying commercial dual layer discs you can make an exact copy of yours.
    Another useful (free) proggie is DVD Decrypter, which can also be used to burn /copy DVD
  6. Drunken Master
    Drunken Master
    May 12, 2001
    836
    In the middle of a roundabout
    +7
    You should try DVDshrink, an excellent peice of freeware, which compresses the contents of the DVD to fit one disc.
  7. lcarter
    lcarter
    Thanks to everyone for your input, I think the way to go is DVD Shrink (know where I can get it).
    Regarding doing an extra copy on the Panasonic DMR-HS2 (good idea) the only thing being is that if both films are 2hrs long then it will take 4 hours to get another copy (long time) just to get a copy, if I am missing something and you can do it easier and faster, let me know, I have only had the machine a month now and maybe have missed something.
    DrunkenMaster just looked at your site, do you get time to watch all your movies again (you have loads).
    Thanks again:hiya:
  8. vonhosen
    vonhosen
    Jan 6, 2003
    1,835
    41
    London
    +13
  9. gab2001uk
    gab2001uk
    Dec 3, 2002
    236
    +5
    When copying the disc recorded on the Panasonic, you are simply duplicating the data at the speed the drive can handle. The length of the video is irrelevant. A 4X DVD writer should do the job in about 15 mins on a full disc of 4.7GB
    You only need DVDShrink or similar to reduce a commercial dual layer 9GB disc to fit on a DVD-R. The Panasonic uses single layer 4.7GB recordable discs
  10. lcarter
    lcarter
    Thanks Graham - seems it straight forward, will only need DVDshrink if it is double layered.
    Txs to everyone for input
