DVD recording from camcorder
Discussion in 'Blu-ray & DVD Players & Recorders' started by Herr Gone, Nov 27, 2004.
  1. Herr Gone
    Herr Gone
    Hello,
    I have a Panasonic NV-GS4 digital video camera which has a ‘S-Video in/out' connection and a ‘DV out' connection but not a ‘DV in.'
    I would like to buy a DVD Recorder to edit my camcorder tapes onto a DVD as I do not have a good enough computer to do it.
    Is this possible, and if it is, how is it done? Also, what kind of things should I look for in a DVD Recorder.
    Thanks.
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,721
    Warwick
    +2,600
    It is indeed possible: look for a DVD recorder with iLink input (DV In). You should decide whether you want a DVD/HDD combo or not: ask yourself if you want to make editted recordings that play on other DVD players. If you do buy a HDD/DVDR such as:
    - Toshiba RDXS32
    - Panasonic E95
    - Pioneer 520
    If not then choose an iLink equipped standalone:
    - Panasonic E65
    - Toshiba DR3
    - Pioneer 320
    - Sony GX700
