DVD recorders
Discussion in 'Blu-ray & DVD Players & Recorders' started by Wayne Moule, Jun 16, 2003.
  1. Wayne Moule
    Wayne Moule
    Aug 4, 2000
    1,365
    48
    +32
    You should be fine with either format.
    The quality is broadcast quality and brilliant at that.
    Possibly.
    Single layered at the mo.
    Why has my post jumped to the top? :confused:
  2. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    leeds UK
    +14
    There is no fight, all formats are viable and have a substantial user base somewhere in the world.
    Pick the machine which suits your needs, I personally love time slip recording where you can pause programs and view the start before the end has finished recording, which is a panasonic feature at present . Other -ram machines in the future should also do this.
    All media is single layer, one hour at best quality, 2 at reasonable.
    Again the flexible recording mode on a panasonic will fit the recording exactly to the media, even if it is 2.5 or 4.5 hours whatever you want.
  3. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    leeds UK
    +14
    The posts are at the top as the first post hasn't been posted yet seeing as his computer is a day ahead of everyone else!
  4. Captain chaos
    Captain chaos
    Can someone give me a brief explanation of DVD recorders and the formats?
    I understand that there has been a fight between the rival manufacturers to push 1 format of DVD recording, as there is DVD R, DVD RW, DVD RAM etc etc.
    Can someone explain if the quality is any good?
    As I understand it, the recording has to be downconverted from digital, to analogue, then back up to digital again to be put on disk - is that correct?
    Also, are the DVD's you buy dual or single layered?
    Thanks for any info you can give me!
    CC
  5. sceptic
    sceptic
    Aug 13, 2002
    663
    Bridgend
    +19
    I'd also be interested to hear views on the sound and picture quality of DVD recorders compared to, say, the Toshiba 220/230 standard.
    If they are as good it seems like the way forward is a recorder/player as one unit in the same way as a VCR.
    Any comments appreciated.
    :confused:
  6. Rasczak
    Rasczak
    Apr 3, 2002
    21,151
    Argyll
    +2,217
    The latest issue of Home Cinema Choice has a roundup of all the DVD Recorders available. I'm not a great fan of HCC but this article seems 'ok'. Recommends you get the DVD recorder that's best for you. A brief summary of the ratings (for what they are worth) were as follows:
    Panasonic DMRE50 - 5 stars (due to Flexible Record/Playback). Rated "Best Budget Deck"
    Panasonic DMRHS2 - 5 Stars
    Rated as the most "flexible and powerful" DVD Recorder.
    Philips 1000 Mk II - 5 Stars
    Rated best playback machine due to the PAL progressive output
    Sony GX7 - 4 Stars
    Rated as a "beautifully made...[and high quality]" machine
    Philips 880/890 - 4 Stars
    Rated as "most affordable" deck.
    Pioneer DVR7000 - 3 Stars
    I suggest you pick up a copy and have a read. Also do a search of these forums (button in the top right hand corner) and will find this is a topic that has been discussed once or twice :D
  7. joshua_bond
    joshua_bond
    Jun 25, 2002
    342
    +16
    It does...but I don't think it is as good as the review as May 2003 of what video. What video not only get into reviews of the latest DVD rec out their but talk a bit on the formats - most informative.
    PS. The HCC did a little piece on Kiss 550 -something I have been searching for some news!!!:)
