DVD Recorders that can record onto 8cm Discs?
Discussion in 'Blu-ray & DVD Players & Recorders' started by the_quarterback, Mar 27, 2006.
  1. the_quarterback
    the_quarterback
    Mar 23, 2006
    75
    11
    Cardiff
    Anyone know if the Pioneer DVR530H can record onto 8cm (mini-dvd) dvd-r's? Or any other models which can play and record onto them?
  2. PhilipL
    PhilipL
    Jan 18, 2002
    3,855
    103
    +461
    Yes the Pioneers can and I think all DVD recorders will assuming they record to full size DVD-R.
    Regards
    Phil
  3. the_quarterback
    the_quarterback
    Mar 23, 2006
    75
    11
    Cardiff
    Cheers Phil... Appreciated... Have a couple of small video clips i've taken with my digital camera - about 30, a minute or so long each and i wanted to put onto 8cm discs to give out to some friends... Thanks... oh and well done on the 1000th post!!!
  4. PhilipL
    PhilipL
    Jan 18, 2002
    3,855
    103
    +461
    Just a thought, if you are handing out the discs the player will also need to support the 8cm discs. You can know that they do because they will have a recess for the 8cm disc the DVD tray, I think most will accept 8cm.
    In terms of cost it will probably be cheaper to use 12cm discs anyway.
    1000th post, never noticed it was that many, must get out more :)
    Regards
    Phil
