DVD Recorders - NTSC Recording from PAL sources?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Dimmy, Oct 27, 2003.
  1. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    As the title suggests, is it possible to record onto DVDs in the NTSC picture format from PAL sources using DVD recorders???
    Thanks for reading
    Dimmy ;)
  2. Easy2BCheesy
    Easy2BCheesy
    May 8, 2003
    343
    16
    Not without buying a standards converter which at the very least is about £600 and offers pretty poor quality.
    I have to admit though that I send a lot of UK TV shows to my friends in the USA - and I record in NTSC using this cunning technique:
    Firstly, I record from Sky+ onto my DVD recorder, producing a PAL disc. Then I put the disc into my £49.99 Safeway Naiko 2000 player which is set to NTSC output. I then re-record in native NTSC. The Naiko is no longer available but just about any of the cheapo Chinese DVD players has the same built-in standards converters and they're all dirt cheap.
    Quality isn't astounding, but it's certainly easily watchable :) I used to have a Samsung multistandard VCR with built-in standards converter and the quality is much better than that.
  3. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    Tesco Dansai players also do a PAL-NTSC conversion
  4. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    Thanks for the feedback guys.
    My Denon 2800 supports NTSC progressive but not PAL Progressive - it also supports PAL-NTSC conversion.
    I was thinking of recording to DVD then playing the recordings through the 2800 and having them de-interlaced - which should yield rather positive results :)
    Thanks again
    Dimmy
