DVD Recorder with Digital Tuner (Tosh RDXS34?) + Cable
Discussion in 'Blu-ray & DVD Players & Recorders' started by howardmg, Jan 6, 2005.
  1. howardmg
    howardmg
    Sep 13, 2004
    123
    Kingston, Surrey
    Would be grateful if someone could explain how a DVD recorder with a digital tuner would work with a cable (Telewest) box. At the moment my only source of a signal is via cable - roof aerial signal is hopeless.
    Does this mean that I wouldn't be able to use the digital tuner and EPG options, unless I sort out my aerial?
    Without this, would the recorder be able to control the cable box channels via the timer? Think I've seen that the Toshiba RDXS32 can do this.
    I plan to wait (if I can hold on that long) for the Toshiba RDXS34 in March - mainly because of HDMI and the 7 day EPG option.
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,197
    Argyll
    +2,257
    Yes - you would need to sort your reception prior to using the internal tuner of the RDXS34 to record Freeview and to receive the associated EPG.
    Obviously we haven't seen the RDXS34 is operation yet but on the assumption that the RDXS34 builds upon the core design of the RDXS32 (and as that did on the RDXS30) then you will still be able to control your cable box via a manual timer. The RDXS34 EPG will be for the internal Freeview channels only.
