DVD recorder that can record multiple formats
Discussion in 'Blu-ray & DVD Players & Recorders' started by jtorry, Jul 10, 2005.
  1. jtorry
    jtorry
    Nov 8, 2001
    523
    I need a recorder than than record pal, pal 60 and NTSC. Can anyone suggest a suitable recorder? Thanks.
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,722
    Warwick
    +2,600
    Not many DVD recorders can do this however the Pioneer range will - the precise model will depend upon your other needs. If you want to archive from a VHS sourse then the Panasonic DMR-ES30V (DVDR/VCR) combi will also do what you want. Some of the Philips range do as well - but you would be well advised to steer clear of them especially if you want to archive from a VHS source.
    Have a look at the 'Which DVD Recorder?' link in my signature for general DVD buying advice!
  3. jtorry
    jtorry
    Nov 8, 2001
    523
    having given the sweetspot another try I had some success with Pal video captures using iuVCR, but today I am trying to capture some NTSC footage from a PS2 game and it is having none of it.
    So can anyone recomend a DVD recorder that can handle multiple video formats?
