DVD recorder newbie
Discussion in 'Blu-ray & DVD Players & Recorders' started by scottbown, Apr 5, 2005.
  1. scottbown
    scottbown
    Feb 18, 2005
    101
    19
    Bristol
    Hi all,
    :lease:
    I'm new to this area of AV forums, spent the last month or so reading the plasma and console gaming sections.
    I want to get a DVD recorder for recording analoge TV at the moment and Cable/sky in the near future. I currently play DVD's via xbox, however it can get a bit tempremental when player copied discs when it's been running for a while. So I'm looking for the DVD recorder to be a good player as well (so Progressive Scan is a must really). Saw the Cambridge Audio DVD53+RW looks good, any comments?
    I'm not bothered about multi-region as xbox plays 'em.
    I've just seen the Panasonic DMRE85 on Richer sounds for £290, looks good and has a hard drive as well. Which sounds great, but do i need it?, Do they do the auto record things like TVIO's do?
    Genral questions about DVD-Recorders:
    -Can i record a TV prog on record then play it back on someone elses stardard DVD player or in a DVD rom drive?
    -Is it better to go DVD-R or +R, i have a dual format burner but only use DVD-R's as they were cheaper and know they work well in xbox.
    -Can you use standard DVD-R Data discs? or do you have to buy DVD Video recordable discs? (like what ya have to do with hi-fi CD recorders)
    Any comments would be great?
    Thanks,
    Scott
    TV: LG RZ-PX11, Player: XBOX, AV Amp: Yamaha RX-v350
  2. scottbown
    scottbown
    Feb 18, 2005
    101
    19
    Bristol
    sorry, ignor my newbie questions i have just found the sticky thread that answers most of them... Doh!
    Still i'd be interested in peoples comments on good DVD recorded sub £200
    Cambridge Audio DVD53+RW - any good?
    also after a quick read i could find a definate answer to "Can i record a TV prog on record then play it back on someone elses stardard DVD player (XBOX) or in a DVD rom drive?"
    and "Do DVD-R's with HD do the auto record thing like TVIO's do?"
    Cheers,
    Scott
  3. ElchenUK
    ElchenUK
    Scott, it is possible to record on a DVD and then play it back on another DVD player or DVD Rom drive in a PC as long as the unit accepts the same format as the DVD disc you are using such as DVD-R, DVD+R etc.
    DVD recorders with built in HDD can perform similar actions as TIVO and SKY+ in that they can pause live TV etc.
    YOu can then transfer any video you have recorded on the HDD to a DVD disc for archiving, this is great for keeping video that you really like.
    I would say that sub £200 players are much of a muchness, it is only once you start getting above that you start to see big differences in quality. I would always recommend Panasonic DMRE55/50 and JVC recorders.
    Hope this helps.
  4. scottbown
    scottbown
    Feb 18, 2005
    101
    19
    Bristol
    Cheers for the advice ElchenUK.
    TIVO and SKY+ have a kind of AI that auto records programs you like, is this possible on DVD recorders with HD? Or is this down to the features of the recorder?
    Scott
  5. ElchenUK
    ElchenUK
    Hope this helps.
  6. ElchenUK
    ElchenUK
    oops sorry for the multiple post!!
  7. ElchenUK
    ElchenUK
    Scott, having never owned a Sky box or a TIVO box I can't really comment. How does the TIVO box know what programs you like? Do you have to categorise programs and then notify Tivo to record those types of programs?
    I know that a of DVD recorders come with videoplus built in, but this is no where near as sophisticated as what you mention.
