DVD Recorder LG4912
Discussion in 'Blu-ray & DVD Players & Recorders' started by garylisa, Sep 12, 2004.
  1. garylisa
    garylisa
    I've justbought a LG 4912 recorder to go with rest of system, I'm happy that I can record images from my DV camcorde; however I was told that I coyuld record original movies, this does not appear to be the case. Is it possible?? :smashin:
  2. Kasparaitis
    Kasparaitis
    Please can you tell me some info on this machine.
    Does it write to dvd-rw and does it have RGB in?
  3. nypdblue
    nypdblue
    May 18, 2004
    38
    11
    I purchased this from Richer Sounds 3 weeks ago and I'm pretty impressed, though not totally.
    In answer yes it does have both dvd-rw & dvd+rw, though the manual does not state RGB Input which is somewhat of a negative.
    After the 2 hour recording mode the quality is pretty poor on 4hr & 6hr options, it really could have done with a 2 1/2 hr & 3 hr record facility like Philips models. The menu set up is impressive with recorded titles playing and chapter breakdown, also PIP facility while watching recordings is useful, finally it's pretty nice looking model.
