DVD Recorder Help Please!!
Discussion in 'Blu-ray & DVD Players & Recorders' started by newcodger, Dec 20, 2004.
  1. newcodger
    newcodger
    Oct 15, 2004
    4
    My dad is after a new DVD or HDD recorder.
    His previous recorder Philips 880 was nothing but trouble.
    he is looking at the new Pioneer range. Now his needs are thus:
    Multi-region
    Pal/Ntsc recording (backups)
    ability to play discs recorded on above Philips machine
    Reliability
    Good picture quality
    I have been looking at the following machines for:
    Pioneer 220, 330 , 420.
    His last machine (880) was purchased via the web. He is a bit dubious about doing this again cos of all the 880 trouble.
    If you can recommend a good reliable web retailer I might be able to sway him.
    I have seen Richer Sounds prices and they are very cheap.
    but the multi-region Toshiba I bought from them just decided to play ONLY region 2 discs for some reason (out of warranty period).
    So I am a bit dubious about using them again.
    any advice would be appreciated.
    sorry if I am a bit of a thicko.
    mike
