DVD Recorder from the High Street
Discussion in 'Blu-ray & DVD Players & Recorders' started by AlexR, Sep 29, 2004.
  1. AlexR
    AlexR
    Hello :hiya:
    I've just had my fingers burn't trying to buy a DVD recorder over the internet with the company going bust :eek: . Thankfully, with the help of my VISA card and bank, I've now got my money back and looking for a new DVD recorder :thumbsup: . I'm now reluctant to get my next one from the internet and my wife definitely is not keen ! :rolleyes:
    Given my choice of stores is limited to John Lewis, Currys, Argos, Comet, Dixons and Richer Sounds, could you please a suggest a suitable DVD recorder. My requirements are:
    - iLink
    - support +RW or -RW (and either +R or -R)
    - preferably supports 3 hours bitrate
    - RGB output
    - preferably RGB input
    - allows RF signal through in standby and normal mode
    - quiet fan (not active while recorder not in use)
    - allows more than one timer programme to be set at any time
    - has a simple user interface
    - I will need to back up a few videos including our wedding video :)
    - it works!
    Out of interest, do either of the following connection combinations work:
    - RGB scart to composite scart
    - Composite scart to RGB scart.
    Any help would be appreciated. :D
    Alex
  2. michaelab
    michaelab
    May 20, 2002
    528
    Lisbon
    +10
    I believe the Sony RDR-GX700 meets all your criteria allthough I think the fan is always on (except when in standby of course). However, I have the GX300 (same as GX700 but doesn't have i-Link) and I don't notice the fan at all.
    Incidentally, the GX300/700 also have component out and prog. scan in case that was of interest.
    Michael.
  3. AlexR
    AlexR
    Hello
    Thanks for the suggestion. From what I can see it looks quite expensive. I was trying to avoid spending more than £300.
    Any more ideas? I did think about the JVC-DRM10 hence the scart question.
    More help please. :lease:
    Regards
    Alex
  4. michaelab
    michaelab
    May 20, 2002
    528
    Lisbon
    +10
    Well, the GX300 can be had for £300 (probably less) - it's pretty much identical to the GX700 except that it doesn't have iLink. IME it's unusual to find iLink on cheaper models but you may be lucky. I don't know the JVC model you refer to but they recently had a different model withdrawn from the market for reliability problems so tread carefully ;)
    Michael.
