DVD Recorder Doesnt Recognise disk. Help!!
Discussion in 'Desktop & Laptop Computers Forum' started by kingh32, Jul 1, 2005.
  1. kingh32
    kingh32
    Mar 6, 2005
    10
    I recently got a new PC that came with a CD/DVD RW all in one recorder (NEC 3100 AD).
    The problem is, it doesn't recognise blank DVDs in the drive so I cant write to DVD-R/RWs at all.
    As its an all in one drive the CD/DVD has to be copied to a temp directory before it asks for a blank disc.
    With CD-Rs it works fine but with DVD-Rs I get no result.
    If anyone could tell me why this happens and what I should do I would be very grateful.
  2. DaveP
    DaveP
    What are the blank disks that it doesn't recognise?
    Dave
  3. kingh32
    kingh32
    Mar 6, 2005
    10
    All types, I've tried RWs, Rs it just acts as if I've done nothing.
  4. DaveP
    DaveP
    Perhaps I mis-undertood your first post. Have you tried both + and - disks?
    I've used Google and my guess is that it is a Dell that you bought.
    I think you may have to call them and arrange a swap.
    Dave
  5. Maff et1
    Maff et1
  6. kingh32
    kingh32
    Mar 6, 2005
    10
    Oh I get it now. Im so clueless with CD/ DVD writers. Correct it is a Dell I had no idea that there was any difference between +/- R. I just assumed it was written with a - traditionally lol. So I need to get hold of some DVD+Rs and try them out.
    I've heard that the model can be upgraded via a firmware download. Is this a safe option?
    Thanks for the help, much appreciated.
