DVD Recorder dies...
hunterm
I have a Goodmans GDVD301RP DVD recorder in order to archive stuff from my Bush PVR. I'm on my second DVD recorder now, the first one died after 2 weeks use and the second one after one night!! The fuse has blown in both plugs and when replaced the unit is still dead.
Could I be wiring the thing up wrong???
BEMUSED!!!
JayCee
BEMUSED!!!
No, extremely unlikely, if it comes with a fitted 3pin mains plug, nothing you do connected with inputs and outputs should blow the fuse.
Just bad luck by the sounds of it or a faulty batch.
If I was in your shoes I wouldn't buy another Goodmans.
