DVD Recorder Conundrum.
Discussion in 'Blu-ray & DVD Players & Recorders' started by lodx, Dec 11, 2004.
  1. lodx
    lodx
    Hi All,
    I am new here and not much of a Technophile.
    I have ordered Sky + and am looking for a dvd recorder home cinema package,preferably multi-region as well.(or can be made multi-region)I have heard of 2 systems.The Panasonic SCHT25R and the Philips LX7500.
    Are these any good?
    Also seeing that some dvds have a hard drive as well should i cancel my Sky +,can the dvd do all sky + can?
    Also what is the situation as of recording off of sky tv? can I do this with my dvd's hard drive etc.Can i transfer from sky + hd to my dvd to make hard copies?
    Lots of questions I know,but would really appreciate some help.
    Lloyd
  2. srobbo999
    srobbo999
    Jul 22, 2003
    134
    The hard drive on the DVD recorder cannot do all that Sky+ can do, it will not be able to record 2 sky channels at once or allow you to watch 1 sky channel and record another. It will allow you to watch record terrestrial tv whilst you record sky or vice versa. You can transfer recordings from your Sky+ to your DVD recorder.
    I have sky+ a dvd recorder, I tend to record things on sky+ and then back them up on to dvd if I want to keep them. It works for me.
    On another note, you say you have ordered Sky+, watch out if you have a plasma or 100hz tv set as the Amstrad boxes that Sky are installing at the moment throw up colour banding problems. If you have ordered via Sky themselves you will get an Amstrad box, if you have gone via a local installer you might try asking him to make sure he fits a Pace box, far better picture apparently. I ordered via Sky and now I am stuck with an Amstrad box with the above mentioned picture problems. :mad:
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    With Sky+ you can record two programmes at once, whilst watching one you recorded earlier. You can also time-slip by just a few minutes.
  4. lodx
    lodx
    Thanks all.Will go ahead with the sky+ and get a recorder without a hard drive as it seems 2 hds would be extravagant!
