DVD recorder and seperate DVD Player
Discussion in 'Blu-ray & DVD Players & Recorders' started by Pip_UK, Jan 24, 2002.
  1. Pip_UK
    Pip_UK
    I am hoping to get the Panasonic DMR-HS1 DVD and hard disk recorder when it is released (hopefully in the next month or so).
    I want to use this for recording digital cable and playing through a DLP projector via S-video.
    With regard to playing pre-recorded DVD's is it worth getting a second DVD player?
    I have component cables to the projector althought the DMR-HS1 has component outputs (also has progressive scan although I jave this on the projector as well). It also has digital coaxial/optical out foir connection to my amp.
    Would this negate getting a second player?
    Cheers,
    Pip
