Dvd recorder and muti region
Discussion in 'Blu-ray & DVD Players & Recorders' started by gabbyevs, May 14, 2005.
  1. gabbyevs
    gabbyevs
    Aug 14, 2004
    154
    sorry dont know if this is the right place to post
    but is there any recorders that are multi region aswell?
    i just looked on argos at a goodmans recorder and although it said region 2 it also said it had ntsc playback which i was a bit confused by
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,721
    Warwick
    +2,600
    You can get multi-region DVD recorders - it is best to buy a pre-multi-region modified one prior to purchase though.
    Cheap rubbish - no RGB input, only DVD+RW/+R recording, cheap build etc. Much better available. Have a look at the 'Which DVD Recorder?' link in my signature for an introduction to DVD recorders. And may I suggest you buy whatever machine you pick online - you'll save a fair amount of cash. Some good (IMHO) online suppliers:
    http://www.rgbdirect.co.uk
    http://www.multiregionmagic.co.uk/
    http://www.avland.co.uk/
  3. gabbyevs
    gabbyevs
    Aug 14, 2004
    154
    thanx just looking at one of the links
    can all thse play on anormal tv doesnt need ntsc?
  4. gabbyevs
    gabbyevs
    Aug 14, 2004
    154
    ive found a rdrgx210s sony
    would this one be good to play on a pal tv
  5. kourosh
    kourosh
    Feb 6, 2005
    14,676
    Portsmouth
    +1,048
    that 1 should be fine :thumbsup:
  6. Rasczak
    Rasczak
    Apr 3, 2002
    21,721
    Warwick
    +2,600
    I would avoid that model as well :) Whilst it is an excellent DVD recorder and player it suffers from an RGB pass through problem that will ruin your enjoyment if you want to record from Sky/Freeview/Cable. The previous Sony models are fine (GX300/GXD500/GX700 but they have all been discontinued now). The Panasonic ES10 is a good choice of a similar callibre.
  7. gabbyevs
    gabbyevs
    Aug 14, 2004
    154
    why wot happens when u record from sky
  8. Rasczak
    Rasczak
    Apr 3, 2002
    21,721
    Warwick
    +2,600
    There is a thread about it on the DVD recorders forum. Probably best you read that rather than me summerising it.
  9. gabbyevs
    gabbyevs
    Aug 14, 2004
    154
    ok thanx
    another question though
    will the panasonic one above u mentioned play back on a pal tv?
