DVD Recorder Advice...
Discussion in 'Blu-ray & DVD Players & Recorders' started by MarkJayne, Oct 18, 2004.
  1. MarkJayne
    MarkJayne
    Oct 5, 2004
    79
    9
    Aberystwyth
    Can anyone recommend a decent DVD recorder with HDD. :)
  2. Rob20
    Rob20
    Jul 3, 2004
    3,107
    +665
    I've got Panasonic's dmr85 which I'm well pleased with. rrp is £600, but Richer Sounds sells it for £400. Highlights include 80GB hdd, excellent editing, ram dvd-r compatibility, prog scan via component out, rgb scart in for excellent digital tv recordings. Very good dvd playback. Has scored highly in all mag reviews. HCC currently has it as there number 1 dvd rec, an has been there since it was released.
  3. Bob H2
    Bob H2
    Aug 27, 2004
    34
    I have the Toshiba XS32 and am more than happy with it. Have had no problems writing to either -R or -RW discs and, having the Harddrive, leaves a VCR for dead - as does the picture quality.
    Editing is quite simple although I prefer to edit on PC.
