DVD Recordable Formats
Discussion in 'Blu-ray & DVD Players & Recorders' started by watl1, Oct 17, 2003.
  1. watl1
    watl1
    Hi everyone
    I am looking to purchase a PC with a DVD rewriter but I'm completely confused as to the different formats! I basically want to be able to play and write onto DVDs, as well as play and write music onto regular CDs. What should I be looking for?
    At the moment, I'm seeing things like:
    DVD & DVDRW
    DVD-RW
    DVD+RW
    DVD/CDRW
    DVD & DVD-RW
    The list goes on!!
    Any suggestions would be appreciated!
    Thanks in advance.
  2. Garrett
    Garrett
    Apr 21, 2001
    40,246
    2
    167
    The best thief you’ll never see.
    +6,666
    Have a look in the Computer hardware & Home Cinema PCs (HCPC) forum there is plenty of questions/answers like that.
    The Pioneer 106 seems to be the best one at present for you needs.
  3. Whatts
    Whatts
    There are 3 formats of recordable DVD:
    DVD+R(W)
    DVD-R(W)
    DVD-RAM
    All 3 use different discs and different recorders so you need to check you are buying the correct type of disc for your recorder.
    DVD-RAM is I think the least widely used and not really of any benefit for you.
    IN the last half a year or so there have also been more and more recorders that can record + and - DVD.
    DVD-R(W) is supposed to be more compatible with other players than DVD+R(W) but most newer players accept both formats.
    DVD/CDRW just means it's a DVD-ROM that can also read/write/rewrite CDs.
    Greetz
    - Tom -
  4. baldbird
    baldbird
    Most DVDRWs are now DVD+/- with the most popular and best models available being the pioneer 106 and the NEC 1300, there's very little between the two but to be honest as Garret says the Pioneer probably edges it.
  5. watl1
    watl1
    Thanks guys! Am now off to check out that Pioneer burner...
  6. Garrett
    Garrett
    Apr 21, 2001
    40,246
    2
    167
    +6,666
    The Pioneer seems compatable with more blank media that tne NEC look here what each disc is recommended for the machine.
  7. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    I am moving this to the "DVD Recorders and media" forum as I think you are more likely to get the info you need there ;)
  8. craig1912
    craig1912
    Dec 16, 2002
    1,734
    +472
    Get the new LG burner that is compatible with all formats
  9. calscot
    calscot
    Oct 29, 2002
    665
    16
    Milton Keynes
    Can you give a link to the LG burner?
    Cheers,
    Cal.
  10. calscot
    calscot
    Oct 29, 2002
    665
    16
    Milton Keynes
    I'll reply to my own question...
    There's a review on zednet
    It's available for £118 from DABS.
  11. nwgarratt
    nwgarratt
    May 5, 2002
    27,186
    +3,037
    I have the LG for a couple of weeks. It has been an excellent piece of kit.
    I got mine for £135 friom Komplett so £118 is even better.
