DVD recommendation
Discussion in 'Blu-ray & DVD Players & Recorders' started by smurf, Oct 30, 2004.
  1. smurf
    smurf
    Feb 10, 2004
    33
    Gillingham
    I have just purchased a Philips 32pf9986, which has a DVI-i connector. I have an Arcam DV88. Do you think I would see a major improvement in picture quality if a replaced my Arcam DV88 with a decent quality DVI-i DVD player (£500 mark)? Any advise would be appreciated, if you would recommend a new DVD player, what player would be best. Thanks
  2. bobbypunk
    bobbypunk
    I think you'd be better to go for a DV79 (Twice what you want to pay) as the HDMI should be compatible with your screen and anything else would be a drop from your existing through component.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,121
    Rainham Essex
    +2,388
    IMO you are unlikely to get a VFM upgrade spending £500 on a new DVI DVD player to watch on a 32" screen. The improvement of DVI over component on a screen of this size may well be noticeable, but I doubt it would be a £500 worth of improvement - unless you are unhappy with the PQ already (come on it's an Arcam, how can you be unhappy with the PQ :nono: ) or just want to upgrade anyway :devil: .
    But at the end of the day only you can decide if it will be money well spent. So you need to get to a dealer and get a home loan of a DVI DVD player to test on your own screen. Then you will KNOW if it would be a worth while upgrade or not.
    Mark.
