dvd/receiver package or separate dvd player and receiver/speaker package?
K
KenH
Hi there.
Being completely new to this I would appreciate any help you could give me. I've looked at dvd/receiver packages particularly the sony davns550, and that seems good. But a couple of friends have advised me to buy deparate dvd player eg sony dvpns705s and then a receiver/speaker package eg sony htddw8405, on grounds of quality and ease of replacement/upgrade. My budget is about £500 for dvd, receiver, speakers and another £500 approx for TV. Our living room is 14 feet square approx. One wall has fireplace in centre with TV cabinet next to it in one corner. Opposite wall has tall dresser where the hi fi speakers sit currently. My friends have systems which can play ordinary tv in some kind of virtual surround sound. What would that be? Is that something the receiver does or the dvd player? Thanks for any help.
Ken
N
nathan_silly
New Sony DVD players are trash.
Sony AV amps are trash.
Virtual surround sound is a gimmick.
What you want is a DVD player WITHOUT a Dolby Digital decoder, ie Pioneer 3xx range or 5xx range. Make sure it has manual region change. Don't bother with Region 2- it's rubbish. Buy Region 1 discs only.
Then you'll need a AV amp that decoders Dolby Digital, DTS. Something like the Onkyo 595 at £450.
You'll need a total of 5 speakers, plus a subwoofer. Spend at least £500 on a subwoofer. £200 a pair on speakers.
I don't want to recommend speakers as we're all different. Go to a friendly HiFi/AV shop, preferbly with a friend with that has AV system him/herself (they will spot the owner if he's telling pork pies)
And you'll need speaker cable, coaxial RCA lead and SCART/S-Video leads.
bob1
Hello ken mr silly didn't read your post very well hes gone well over your budget £500 just on the sub.The only thing i can say is the pioneer dvds are very good for the price you can get a pioneer 350 multi region dvd player for £130 on the net,that would leave you £370.It would be better to spend as much as you can on the amp they should all give you surround sound from the tv try to get one with dpl2 if you can. spend less on the speakers you can upgrade bit at a time its taken me a year for me to upgrade the speakers to a full matching set.But in the end make your own mind up and go and listen to the stuff before you buy.
N
nathan_silly
I did read the post, unfortuantly most amp/5.1 speaker packages are pretty bad (and the DVD/amp/speaker 5.1 are even worse!)
I would just fork the extra, if you get a cheap unit it'll probably pack up within a year or so. Like the previous poster said, get a high-current amp ie Krell (just kidding!) Don't buy Technics, Sony or JVC.
Then buy a good set of L/R speakers. Then rears, then centre, and then eventually subwoofer.
To put your limited entire budget for everything is reducing the overall performance dramtically.
for example...
28" 16:9 TV- £400
High Quality AV amp- £350-£500
DVD player - £250-£300
Main speakers- £200-£300
14' square is a medium size room, I doubt a £500 complete package will be sufficient.
Andywilliams
hi kenh
have a look at yamaha hti-b 60 you get a quality amp dvd player and 5-1 speaker setup for around £520 .You won't be disappointed everything is easy to upgrade it is a good value set up cheers gonzo.
sounddog
for example...
28" 16:9 TV- £400
Unfortunately not everyone has such deep pockets Mr Silly. Infact yout suggestions are just plain silly considering what the OP put.
Contry to Mr Silly's sugestion, you can get a good system for £500.
Sony DVD players are NOT trash and Sony AV Amps are NOT trash.
I would suggest you should look in the reigion of £200 for the amp (e.g. Marantz SR4200).
Then around £100-150 should be sufficiant for a good DVD player (Toshiba 220, Pioneer 350, etc)
That will leave you around £150 for a speaker package. Forget the Sub and spend the money on an Eltax or Gale package from Richer Sounds.
Then at a later date, you can consider adding a sub.
for example ... (from Richer Sounds advert)
Amp - Marantz SR4200 (with PLII / DD / DTS) £200
DVD Player - Toshiba SD220E (Multiregion) £135
Speaker Package - Eltax Liberty 5.0 Package £150-180
Total £500 give or take pocket change :)
Add to that £20-30 for a decent interconnect and some speaker cable to wire it all together.
Yes this will not give you the BEST system in the world. But will give you many hours of enjoyable entertainment without completly breaking the bank.
And the best thing about spending your £500 this way rather than on an all in one system is that when and if the time comes, you can upgrade in stages rather than having to throw it all out and start again from scratch.
I know, as this is how I started out (different kit at the time but similar costs) and don't regret a single penny of what I've spent.
Just remember ... Buy within your budget and have great fun listening to the films. You don't have to spend a fortune to enjoy yourself, just get the best you can within your budget, sit back and enjoy it.
Victoria
sounddog
Oh ... and a Thompson 28" Widescreen is a pound under £400 ... and this is from Curry's!!!
I'm sure you'll find better bargins elsewhere (online).
So there you go ... a whole system which WILL give you many hours of joy WITHOUT breaking your £1000 original budget.
Victoria
N
nathan_silly
The Toshiba's are good DVD players-excellent picture- however..
1) Slow menu operation with Disney releases
2) Noisy transport.
3) Impossibly hard to use remotes.
4) Auto Region is not a good mod. Make sure it has manual Region change. Otherwise RCE Region 1 disc's will either refuse to play or you have to do a disc swap method. And if RCE2 comes out (or a new region checking method) it will just not work
Sony amps are good then? hmmm...Rotel's are MUCH better.
What about Sony's DVD player Chroma problems?
Marantz- ok.
sounddog
2) Noisy transport.
Marantz- ok.
Your reply really doesn't deserve a detailed reply ... you're just being plain silly.
I'm trying to help the OP ... contry to what you are saying your CAN spend £500 on decent home cinema.
Don't like the Toshiba DVD player ... buy a Pioneer or Philips. Don't like the Marantz amp ... buy a similarly priced Denon or Yamaha. There are lots of options!
For £500 you can't expect to better a Rotel system ... but you can get a good system.
Victoria
K
KenH
Thanks for all your advice and suggestions. Very helpful! Am definitely going for separates now rather than an all-in-one system. Keep the advice coming!
Ken
N
nathan_silly
Philips?? oh dear... don't start me off with philips..
Noticed you recommended Thompson TV's. oh god!
Have you noticed you recommended the Marantz amp- and then said you don't like them? what's up with that?
Do you not know of the Sony NS300 and NS400 chroma problem? Do you also know the £1000 7700 and £1600 9000ES ALSO has this problem? It's pretty obvious Sony does not even care about it's flagship player!
I was comparing a Rotel v Sony integrated amp (on general sound quality) The Rotel AV amps are a bit too much I agree. But some people jump onto the all-same make Sony/Technics bandwagon.
Don't even bother with something like the Sony DAV units. The "subwoofer" is more like a "parpwoofer!"
Decent? no. 1st AV system?- ok.
Nobber22
Nathan, could you please be a little less...um, "forceful" with your product/region bashing? I see you have a few issues with certain products and manufacturers, but slagging off every poor product in the OP's sights is not helpful. As Sounddog kept trying to tell you, this thread is for (primarily) KenH's benefit and those who are in the same boat as he is.
Now you may have had some bad experiences with Tosh or Sony or Thompson, but I think most people here prefer to gently point someone seeking help in the right direction (in your opinion of course) and not go "off on one!"
Newbies find AV intimidating enough without you introducing loud and forceful statements into your posts. I realise that Sounddog appears to be more than a newbie, but poo-pooing every one of his suggestions so scathingly is just rude. Please try to be more patient.
Thanks. :)
N
nathan_silly
You think I'm being rude?
Do you want me to recommend products which are just plain bad then?
As for "Region" I take it you're talking about me bashing Region 2. It is rubbish. Why bend the truth?
If he can't take advice on "what not to buy" then he soundn't come here. Just walk into Dixons. For example reading comments on Apex and Scan DVD player's he should make a pretty obvious conclusion.
I agree with Soundog on Pioneer DVD player!
I was a newbie once- I bought a Aiwa midi system. I wish I had access to the internet- I would have taken in peoples bad comments in.
Nobber22
It's not your advice, it's your tone. Be a bit nicer please. Chill out. This forum is generally a friendly & pleasant place to visit, so one would like to see everyone being nice to each other. Perhaps I'm just old-fashioned :rolleyes:
N
nathan_silly
I am being nice to him! by explaining what is terribly bad and why- he won't have the stressful experience of buying it!
If I just say "the scan dvd player is ok" he won't know it's not.
If I say "the scan is *************** and ********* and it burns out and catches fire. Don't you think that's better? At least he won't have wasted £100, then he'll have to buy another one!
Ian J
You could always start by reading the question properly. It is of no help to anyone if you intend to answer questions that haven't been asked.
H
hutchingsp
Into the Lions den :D
I would go for separates every time unless you really really want something discreet and "designer" looking.
You can get TVs with dolby, either with proper centre/rear speakers, or with a virtual dolby, but you'd probably be pushing it for £500, plus I don't think it would sound nearly as good.
IMHO one of the biggest problems you'll find is that for that sort of budget you can get decent kit, but it may be hard to find a dealer that'll let you try it out - rightly or wrongly I suspect a lot of them won't want to time and effort just to sell a £150 amp.
I'd take a look on the Richer Sounds website and get a couple of magazines to get a feel of what you can get for what sort of money...
This is just an opinion but I would suggest spending £150-200 on an amp/receiver and £120-150 on a DVD player - spend as much as you can on the speakers as better speakers with a lesser amp will give you a better sound than lesser speakers and a better amp.
Personally I have a Sony 830 receiver that's a couple of years old, and a Toshiba 2109 DVD player that's a couple of years old, my speaker setup is a front pair of B&W DM601s2 that cost £200, the rears are a pair of Mordaunt Short MS05s that cost £40 and the centre is a Gale Centre 10 that cost £20 from Richer Sounds last Saturday.
If I were to replace it all I believe I could buy a suitable amp for around £200, an equivelent Toshiba DVD player for £120-130, but I'm not sure I could get speakers as good as the B&Ws for less money.
Everyone has their preference on what they consider good and bad, that includes dealers (they also have their profit margin thrown into the equation) so you will get conflicting advice - I'd take everything with a pinch of salt.
regards
Paul
Nobber22
I'd agree with everything hutchingsp said up to the point where he has partnered his B&W's with a Gale centre speaker. Accepted wisdom is to use matching speakers across the front 3 to get a uniform soundstage. I reckon his Gale will be swamped a bit by the B&W's and make the dialogue harder to hear IMO :)
He probably was on a budget and wanted surround sound, but that Gale is likely to hold his setup back a little. I'm sure he'll look to get a matching B&W soon :)
N
nathan_silly
Agree with nobber- you need a high quality centre speaker, more important to have quality centre than fronts or rears. Natural sounding speaker is a must. But then I have a Kef Model 200!
gonna get more flames here- I also the B&W CC6. Lacking in midrange ability for voice, sounds a bit aritficial, bass a bit whoompy. Treble is a bit splashy. Biamped, with 100W amps.
Kef Q95C is better, Model 100 better still. And 200 even better.
H
hutchingsp
It's a bedroom setup, the previous centre speaker was a Mordaunt Short MS209c in cherry/maple finish.
I'm taking delivery of a Panasonic TX28PL1 this weekend and I wanted something physically smaller, and in a black finish just to look a little more "right" - I don't have money to burn but for £20 if I use it for a month and then get a B&W....
It's just forcing myself to get over the "£200 for a speaker" mentality.
regards
Paul
K
KenH
Hi again
Thanks for all your replies! very interesting and thought provoking. One thing I did not make clear at the beginning is that I will not be thinking of upgrading in 12-18 months time. I can just about just afford to buy a system which hopefully will last for some (years). If it helps, I bought my current Technics hi fi system for £500 about 7 years ago, and haven't felt the need to upgrade it. I'm not really into top quality gear, just something that'll work well and give decent quality. That's just the way of our finances: mortgage, children at university etc etc. so not a lot left; and I don't want to use credit! So that's why I'm aiming to buy the dvd player, amp and speaker system now, I won't have any 'spare money' later! One more thing about the speakers. One of the things we, especially my wife, liked about the dav system was the small size of the speakers ('they'll fit on the TV cabinet around the TV'). With the speaker systems you recommended, are the speakers of a similar size or are they larger speakers like my Technics (14" x 8")? Finally, I had thought that this system would replace my hi fi system, but your replies seem to suggest that you have separate hi fi systems and home cinema systems - am I correct?
Thanks again.
Ken
H
hutchingsp
It's six of one and half a dozen of the other really - if you want something that you can stick in, looks good, is descreet, and easy to use, and that you'll probably be delighted with 95% of the time I suspect there's an all-in-one that will suit you (I wouldn't want to suggest one as I don't know enough about them).
On the other hand if you want generally "better" quality and something that you _could_ upgrade if and when you want to then I'd still suggest separates, but with the obvious caveat- more unsightly, and generally larger boxes.
You definately don't need a separate music and AV system - maybe when you step into audiophile territory, but if (as it sounds like) you've a living room that's used by the family and you like to watch TV/movies or stick on some music then there's no need at all.
I have to say that whilst it isn't everyone's cup of tea due to being an all-in-one, the Sony DAV-S550 does look bloody nice..
regards
Paul
N
nathan_silly
Satellites/subwoofer combinations are not suited to music. Primarly use is AV.
The minimum size speaker for stereo pair would be a two way, standmounter with a 6 / half " woofer/midrange, and 25mm soft-dome tweeter.
In music the DAV would sound very harsh, with a lower bass gap between the subwoofer and satellites. If you tried replacing the DAV sub with a expensive subwoofer you might be able to get away with it. However a £500 bundled subwoofer cannot fill the 50hz (LF corner on a standmount) to 120hz- 240hz (lower midrange)
Yes I have two seperate systems. A Stereo Transport/DAC/Pre-Power setup/biamped speakers, and DD Processor, several poweramps, subwoofer, centre and rears.
The DAV system won't have the frequency range of your Technics speakers
flat spot
I think the bottom line is this. For the money you have seperates aren't really an option. Go for the best all-in-one system you can afford. Obviously these aren't to everyones taste but I think you would be happy with it. They're more practical if nothing else:D
sounddog
Sorry ... ended up posting same thing twice so have deleted one of them.
Trending threads
Latest News
AVForums Podcast: 9th August 2020
  • By Phil Hinton
  • Published
Linn announces Majik DSM digital streamer upgrade
  • By Andy Bassett
  • Published
Sony announces WH-1000XM4 noise cancelling headphones
  • By Andy Bassett
  • Published
McIntosh launches C22 Mk V preamp and MC1502 power amplifier
  • By Andy Bassett
  • Published
Marantz unveils 12 Series Special Edition models
  • By Andy Bassett
  • Published
