DVD RAM to DVD +R
Discussion in 'Blu-ray & DVD Players & Recorders' started by Ivesy, Aug 26, 2004.
  1. Ivesy
    Ivesy
    Hi I have just bought a Panasonic DMRE55 and would like to know if it it possible to transfer the recordings I have made from the DVD RAM Disk to a DVD 'plus' Disk on my PC? My PC can read the RAM disk but if I use Nero for example to copy the files then it says "unrecognised format" these VOR files and not VOB (apparently) is there anyway to convert them? I've also discovered in the manual that it only plays the 'minus' format which was a shock as ALL my disks are 'plus' luckily about 95% work. I've just looked at the advert again and it states it reads DVD R and DVD R/W but it doesn't say wheather 'plus' or 'minus' I assumed both!
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,868
    Warwick
    +2,785
    Doesn't anybody look at the existing posts before they post a new topic these days? :suicide: Look at this thread.
  3. Ivesy
    Ivesy
    Cheers! I'll have a look a that tomorrow! Thanks for the help.
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,868
    Warwick
    +2,785
    No problem - you'll generally find I keep saying DVD-R throughout the guide but the process is identical for converting to DVD+R.
