DVD-RAM recording...
Discussion in 'Blu-ray & DVD Players & Recorders' started by cerebros, May 14, 2003.
  1. cerebros
    cerebros
    Dec 27, 2002
    1,190
    38
    Leicester
    +11
    While most DVD players can't accept DVD-RAM caddies, as DVD-RAM is part of the official DVD specs, should all DVD players be able to play caddyless DVD-RAM discs? I know that you can get caddyless DVD-RAM discs, and you can also buy blanks without caddies, so i was just wondering what the situation was regarding playback...
  2. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    leeds UK
    +14
    Its unlikely as they also need to know how to read the data which is laid down in a different format to +rw and -rw.
    Its also impossible to finalise a -ram so you cant even make it look like a normal dvd for playback
  3. Cabo 5150
    Cabo 5150
    Nov 21, 2002
    103
    +3
    By the way, it's very easy to take RAM discs out of the caddy and vice versa.
  4. DaveP
    DaveP
    The new Panasonics play caddyless disks and I suspect any new models from Tosh may well do once their DVD recorder is established.
    DaveP
