DVD-RAM Reader
Discussion in 'Blu-ray & DVD Players & Recorders' started by barbaramac, Nov 22, 2004.
  1. barbaramac
    barbaramac
    Oct 7, 2004
    28
    Glasgow
    I have a Dell Dimension 4550 with a DVD-ROM reader. I would like to change this to a DVD-RAM reader as I have a Panasonic DMRE55 and would like to copy from RAM discs to my PC so that I can burn to DVD-/+R. I have an External DVD writer which does not read RAM. Could I do this myself, is it easy, and what DVD-RAM reader can anyone suggest? Can I, for example, buy an external DVD-RAM reader?
    By the way, I am extremely pleased with the Panasonic DMRE55. Excellent results and so easy to use.
  2. johnjackthom
    johnjackthom
    Sep 20, 2001
    748
    Northumberland
    +283
    not sure if there's an external drive which handles RAM but it should be fairly simple to replace the present DVD-ROM drive with the latest offering from LG.
    Here it is at Dabs.com for around £50.
    You may well find it cheaper elsewhere. :)
  3. SDHoward
    SDHoward
    Nov 1, 2004
    250
  4. bigsby
    bigsby
    Apr 14, 2004
    270
    +9
    I got the LG from Dabs and an IDE to USB lead from Maplins for £20.
    Fine for a laptop, should be simple enough to fit the LG into your Dell though.
  5. Kevo
    Kevo
    Aug 23, 2001
    5,397
    Manchester
    +149
    I bought something similar at the weekend.....
    A 3.5" enclosure that converts any IDE/ATAPI drive to USB 2.0 for £20
  6. barbaramac
    barbaramac
    Oct 7, 2004
    28
    Glasgow
    Thanks everyone for your help. I have finally bought a DVD-ROM drive which reads DVD-RAM. An LG-GDR8163BB with a black fascia which matches my black Dell computer at a cost of £21.50 including p&p. Not a bad deal, eh? I just hope I can fit it ok. In case anyone is interested, I bought it from www.komplett.co.uk. :)
  7. OARDVD
    OARDVD
    Jul 6, 2003
    241
    16
    Deepest Hertfordshire
    You may need to download a driver to read RAM (if one isn't supplied with it).
  8. barbaramac
    barbaramac
    Oct 7, 2004
    28
    Glasgow
    Help! I though I was being smart but when I copied a film I had recorded from TV from my DVD-RAM onto a DVD-R it would only play on my PC. I tried it on my Panasonic DVD Recorder, a Pioneer DVD Player and a JVC player. Can anyone help or have I just spent £22 on something which I cannot use? I did not 'finalise' the DVD-RAM as I wanted to use it again, I don't know if this has anything to do with it. :lease:
  9. SofaSpud
    SofaSpud
