DVD-RAM read/write cycles and durability
Discussion in 'Blu-ray & DVD Players & Recorders' started by derb, Mar 30, 2003.
  1. derb
    derb
    Has anyone had problems with degredation of disc quality either over time or over use with DVD-RAM discs? I would probably end up re-recording on them several times each and would want to keep them for several years. Obviously nobody here has had DVD-RAM recordings on the shelf for several years, but I would be interested in any early indications...
  2. TommyVecetti
    TommyVecetti
    Feb 10, 2003
    1,763
    uk
    +95
    I haven't had any problems. YOu should be able to record on them thousands of times over.
  3. Rasczak
    Rasczak
    Apr 3, 2002
    21,203
    Argyll
    +2,260
    Actually as a format DVD-RAM has been around and in use for over five years now. It does what it says on the tin - it is a very safe way to store data long term. My company uses DVD-RAM as the backup storage medium (due to it's random access).
    Even if the disk gets damaged then the error correction facility integral to RAM means it *should* still work. Yet to experience a bad recording though - and I have been using RAM (for data) for just under 2 years now.
  4. vonhosen
    vonhosen
    Jan 6, 2003
    1,835
    41
    London
    +13
    DVD-RAM is far more durable than DVD-R/+RW & is idealy suited to archiving.
    DVD-RAM has a long shelf life and caddy discs should be good for about 100,000 re-writes whilst the later two should be good for about 1,000 re-writes each.
